[GRASS-user] db.? to change column names
Rich Shepard rshepard at appl-ecosys.com
Fri Aug 31 09:03:38 PDT 2018
On Fri, 31 Aug 2018, Moritz Lennert wrote:
> To get the data into columns, try this:
> v.db.addcolumn stations col="easting double precision, northing double
> precision"
> v.to.db map=stations opt=coor columns='easting,northing'
> Then you should see the easting and northing columns in the attribute table.
> Not need to export and reload.
Moritz,
   Thanks very much.
   The data were exported in preparation for reading into R.
Best regards,
Rich
