[GRASS-user] creating a new mapset in an existing location
Moritz Lennert mlennert at club.worldonline.be
Wed Jul 11 02:35:32 PDT 2018
On 11/07/18 11:24, Ken Mankoff wrote:
> Dear List,
> Is there a way to create a new mapset from the command line?
> My use case is that I'd like to run parallel jobs (with GNU parallel).
> But,
>> ...it's recommended to launch each job in its own mapset within the
>> location.
> according to ttps://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs
> I'd like to have the parallel calls create the new mapset, each named JOB_SLOT_NUM (up to n CPU cores). I don't know in advance if I'll be spawning 4, 8, 16, etc. parallel jobs.
grass -c /PATH/TO/LOCATION/newMapsetName
does the trick.
If you only want to create the mapset, but not enter it, you can use:
grass -ce /PATH/TO/LOCATION/newMapsetName
Moritz
