[GRASS-user] script GUI > G_OPT_V_INPUT vs G_OPT_V_MAP
Markus Metz markus.metz.giswork at gmail.com
Sun Jul 22 07:31:17 PDT 2018
On Sun, Jul 22, 2018 at 10:13 AM, Frank David <frank.david at geophom.fr>
wrote:
> Hello,
> I don't understand the difference between these two entries. Both seems
to work in a same way for my purpose ...
Modules use G_OPT_V_INPUT if a new output map is produced, and use
G_OPT_V_MAP if no output map is produced, e.g. v.info, v.db.connect. The
same applies to raster input.
Markus M
> Thank you for your advice.
> Best regards,
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180722/596f4761/attachment.html>
