[GRASS-user] Problem importing ESRI grid file (.adf)
Helmut Kudrnovsky hellik at web.de
Sat Jun 9 09:28:25 PDT 2018
Rich Shepard wrote
> On Fri, 8 Jun 2018, Helmut Kudrnovsky wrote:
>> Have you looked into GDAL's "AIG -- Arc/Info Binary Grid" format
>> description?
> Helmut,
>    I now have. Not much information (the format spec page didn't want to
> load), but it appears to be what I need for the DEM: a raster with small
> size cells, each having a geographic coordinate and elevation.
>    The format is installed here:
> $ gdalinfo --formats | sort
>    AAIGrid -raster- (rwv): Arc/Info ASCII Grid
>    ACE2 -raster- (rov): ACE2
>    ADRG -raster- (rw+vs): ARC Digitized Raster Graphics
>    AIG -raster- (rov): Arc/Info Binary Grid
>    The output is not what I expect; see attached .png. I'm open to all
> suggstions and recommendations because I must be doing something
> incorrectly
> here and do not see what that is.
>    The command line used is:
> r.in.gdal -o --overwrite
> input=/home/rshepard/.../data/topography/LDQ-45122C3/2014_OLC_Metro/Bare_Earth/bh45122c3/hdrbnd.adf
> output=bare_earth
> (wrapped by alpine; it's entered as a single line).
>    That directory with all files should be downloadable from my dropbox
> public directory:
> <https://www.dropbox.com/preview/Public/bare_earth.tgz?role=personal>
> Regards,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
As always recommended, look at the output of gdalinfo, compare it with the
computional region of your interest and then decide if the data expects your
need.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
