[GRASS-user] rshepard at appl-ecosys.com sent you a file
Markus Metz markus.metz.giswork at gmail.com
Mon Jun 11 09:14:05 PDT 2018
On Mon, Jun 11, 2018 at 3:05 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >I can not confirm, because ...
> > identical, only that trunk is able to resolve the name of the unit
> what I can observe here with
> GRASS version: 7.5.svn
> GRASS SVN revision: r72772
> Build date: 2018-06-06
> Build platform: x86_64-w64-mingw32
> GDAL: 2.2.3
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200 (OSGeo4W)
> startup GUI -> new location -> read projection and datum terms from a
> georeferenced data file -> then reference to
> D:\temp\rich\Bare_Earth\bh45122c3\hdr.adf
> no SRS information is reckognized at, new location can't be build. and I
> can't import the raster data by r.in.gdal.
strange, works for me on Linux.
can you provide the winGRASS 7.5 output of
g.proj georef=D:\temp\rich\Bare_Earth\bh45122c3\hdr.adf -p
and
g.proj georef=D:\temp\rich\Bare_Earth\bh45122c3 -p
thanks!
gdalinfo reports as SRS
PROJCS["unnamed",
    GEOGCS["Unknown datum based upon the GRS 1980 ellipsoid",
        DATUM["Not_specified_based_on_GRS_1980_ellipsoid",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6019"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4019"]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["standard_parallel_1",43],
    PARAMETER["standard_parallel_2",45.5],
    PARAMETER["latitude_of_origin",41.75],
    PARAMETER["central_meridian",-120.5],
    PARAMETER["false_easting",1312335.958005249],
    PARAMETER["false_northing",0],
    UNIT["user-defined",0.3048]]
which is ok.
I'm using gdal-2.3.0 and proj-5.1.0
Markus M
> whereas both above works in winGRASS 7.4.0
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180611/b4bc10b3/attachment.html>
