[GRASS-user] problem
Andrea Balotti balotti.and at gmail.com
Sat Jun 16 13:59:44 PDT 2018
Hi,first of all, have you set the region?
Andrea
Il giorno sab, 16/06/2018 alle 12.47 +0300, hindo kush ha scritto:
> All,While calculating Net Radiation i have to run the r.sun module
> and i did exactly what it was in the manual but the problem is this
> that i don't get any output any hint!!!
> (Sat Jun 16 12:39:45 2018)
> r.sun elevation=Dem at PERMANENT aspect=aspec at PERMANENT slope=slp at PERMAN
> ENT albedo=Albedo at PERMANENT lat=latmp at PERMANENT long=longmp at PERMANENT
>  incidout=IRdAnM1 beam_rad=BIrdM1 diff_rad=DIrdM1 refl_rad=GrIrdM1
> glob_rad=GIrdM1 day=207 time=6
> Number of threads <1>
> Mode 1: instantaneous solar incidence angle & irradiance using a set
> local time
> Using Linke constant: 3.000000
> Using albedo map <Albedo at PERMANENT>
> Using slope map <slp at PERMANENT>
> Using aspect map <aspec at PERMANENT>
> (Sat Jun 16 12:39:53 2018) Command finished (8 sec)
> GRASS 4.1
> windows 64bit
> 16Gp Ram
> kindly see the attached picture as well
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180616/cd6ea47e/attachment.html>
