[GRASS-user] i.nightlights.intercalibration, Problem with running code
Nikos Alexandris nik at nikosalexandris.net
Tue Jun 19 19:07:27 PDT 2018
Dear Gabriel,
try this:
i.nightlights.intercalibration image=$(g.list rast pattern=F* sep=,)
Details: the command `g.list` is not actually run, I think.
Use the proper syntax, which is to enclose the command with a
"$(g.list type=raster)".
In my repository, and in the the manual there is still some demo
command using backticks, like:
i.nightlights.intercalibration image=`g.list rast pattern=F* sep=,`
which is the old style. Better the new style, i.e.:
If you don't do this, the module will "think" that the option `image`
is fed with only:
image=g.list
and the rest of the line will be treated as extra arguments.
Nikos
----- Original Message -----
 "Gabriel Cotlier" <gabiklm01 at gmail.com>
To:
<grass-user at lists.osgeo.org>
Cc:
Sent:
Tue, 19 Jun 2018 12:44:33 -0300
Subject:
	Problem with running _i.nightlights.intercalibration
_
_ for the
_Elvidge(2014) model-coefficients.
	 Steps I have followed:
	1.I have imported the following layers:
	(Tue Jun 19 12:29:20
2018)
	g.list
type=raster
	F101992
	F101993
	F101994
	F121994
	F121995
	F121996
	F121997
	F121998
	F121999
	F141997
	F141998
	F141999
	F142000
	F142001
	F142002
	F142003
	F152000
	F152001
	F152002
	F152003
	F152004
	F152005
	F152006
	F152007
	F162004
	F162005
	F162006
	F162007
	F162008
	F162009
	F182010
	F182011
	F182012
	(Tue Jun 19 12:29:21 2018) Command finished (0
sec)
	2. I have run the code on the dialog box of
__ :
_
	_
_
	3. I got the following error message:
	(Tue Jun 19 12:31:26 2018)
	i.nightlights.intercalibration image=g.list type=raster
       suffix=c model=elvidge2014
	|i Inter-satellite calibration of DMSP-OLS Nighttime Stable Lights
	WARNING: Operating on current region
	|> Calibrating average visible Digital Number values
	WARNING: No data base element files found
	  File "C:UsersGabrielAppDataRoamingGRASS7addons/scrip
	ts/i.nightlights.intercalibration.py [1]", line 525, in <module>
	    sys.exit(main())
	ts/i.nightlights.intercalibration.py [2]", line 340, in main
	    model_parameters = retrieve_model_parameters(Model,
	*args)
	ts/i.nightlights.intercalibration.py [3]", line 242, in
	    model = model_class(*args, **kwargs)
	  File "C:UsersGabrielAppDataRoamingGRASS7addonsetci
	.nightlights.intercalibrationintercalibration_models.py",
	line 155, in __init__
	    CalibrationModel.__init__(self, author, satellite, year)
	line 43, in __init__
	    year=self.year)
	line 63, in verify_year
	    available_years = COEFFICIENTS[author][satellite].keys()
	KeyError: 'g.l'
	(Tue Jun 19 12:31:27 2018) Command finished (1 sec)
	Thanks a lot for your help
 and
assistance
	Best regards,
	Gabriel
Links:
[1] http://i.nightlights.intercalibration.py
[2] http://i.nightlights.intercalibration.py
[3] http://i.nightlights.intercalibration.py
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180620/285af4a6/attachment.html>
