[GRASS-user] question on i.nightlights.intercalibration code
Gabriel Cotlier gabiklm01 at gmail.com
Sun Jun 24 20:40:16 PDT 2018
Hello,
I think I have found a similar situation solved for Linux version at:
https://trac.osgeo.org/grass/ticket/2757#comment:21
In my case I'm using GRASS 7.4.0 in Windows 10, and when I called for
metadata info of the layer I got the message bellow with the problem
highlighted in yellow bellow.
What could be happening? It would be very helpful to understand what is
happening and how to solve importing many raster layers without this extent
problems.
I appreciate your help.
Thanks a lot in advance.
Regards,
Gabriel
(Mon Jun 25 00:30:03 2018)
r.info map=F101992 at PERMANENT
 | Map:      F101992 at PERMANENT              Date: Sun Jun 24 23:29:43 2018
 | Mapset:   PERMANENT                      Login of Creator: Gabriel
 | DataBase: C:\Users\Gabriel\Documents\layers
 | Title:    F101992
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         16801
 |   Columns:      43201
 |   Total Cells:  725820001
 |        Projection: Latitude-Longitude
 |            N:  75:00:15N    S: 65:00:14.997984S   Res: 0:00:30
 |            E: 180:00:14.994816E    W: 180:00:15W   Res: 0:00:30
 |   Range of data:    min = 0  max = 63
 |   Data Description:
 |    generated by r.in.gdal
 |   Comments:
 |    r.in.gdal -e input="C:\Users\Gabriel\Documents\layers\F101992.tif" o\
 |    utput="F101992" memory=300 offset=0 num_digits=0
360 degree EW extent is exceeded by 0.999827 cells
360 degree EW extent is exceeded by 1.99983 cells
(Mon Jun 25 00:30:04 2018) Command finished (0 sec)
<http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.
www.avg.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
On Sun, Jun 24, 2018 at 5:09 PM, Gabriel Cotlier <gabiklm01 at gmail.com>
wrote:
> Dear Vero and Markus,
> Thanks a lot for the guidance and help.
> If I understood correctly:
> I first have to import one layer when I select a location setting the
> coordinate system of that layer to the mapset of GRASS (at the start).
> Then I have to import all other layers to mapset using command "r.in.gdal
> -a"
> r.in.gdal -a input=C:\Users\Gabriel\Documents\layers\F121995.tif
> output=F121995
> Then I have to running "g.region" to set up the same extent to all layers
> as follows:
> g.region raster=F121995
> and I got the layer processed and finished but the error did not went
> way....
> |i Inter-satellite calibration of DMSP-OLS Nighttime Stable Lights
> WARNING: Operating on current region
> |> Calibrating average visible Digital Number values
> Regression coefficients: (-0.0515, 1.2293, -0.0038) | Associated R^2:
> 0.9178
> 360 degree EW extent is exceeded by 1 cells
> WARNING: As requested, timestamp transferring not attempted.
> WARNING: No data base element files found
> (Sun Jun 24 17:05:31 2018) Command finished (1 min 2 sec)
> What could be doing wrong?
> In addition I'm doing it for one layer here, is there a way to do it for
> many layers at onces with command line or GUI dialog box?
> Thanks a lot again.
> Gabriel
> On Sat, Jun 23, 2018 at 6:31 AM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> On Sat, Jun 23, 2018 at 11:10 AM, Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > Hi,
>> > El sáb., 23 jun. 2018 4:35, Markus Metz <markus.metz.giswork at gmail.com>
>> escribió:
>> >> On Fri, Jun 22, 2018 at 10:34 PM, Veronica Andreo <
>> veroandreo at gmail.com> wrote:
>> >> > Hi Gabriel,
>> >> > What you could do is import with r.in.gdal -a  that adjusts
>> resolution for lat long maps [0]
>> >> that will help to fix the resolution from 0.008333333300000 to
>> 0.008333333333333, i.e. exactly 30 arc-seconds. The software used to create
>> the raster data has stored the resolution with limited precision.
>> > Right, I overlooked this
>> >> > and then (before the intercalibration step), set the region to one
>> of the imported maps with g.region raster=yourmap
>> >> you will then get a message like
>> >> which is correct because the first and last column are duplicates. The
>> cell centers cover -180, 180, and the EW extents regarding cell borders are
>> E: 180:00:15E, W: 180:00:15W, grown by half a cell, i.e. 15 arc-seconds.
>> > So, solution is to just use the data with the extra 15 arc-seconds in
>> each side?
>> yes, or chop off the first or last column: set the region to the raster,
>> then modify the current region with g.region w=179:59:45W -p
>> > Of I want data to fit 180/-180, would r.region mymap e=180 w=180 help
>> or will it change the data?
>> this would modify the data because
>> 1) the raster will be shifted by half a cell to the east
>> 2) the cell size (ew resolution) will be changed
>> Markus M
>> > Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180625/71dd7460/attachment-0001.html>
