[GRASS-user] v.out.postgis
Paul Shapley p.shapley at gmail.com
Thu Jun 28 00:59:31 PDT 2018
I am trying to export a vector map to PostGIS. Has anyone come across the
'Unable to describe table' error? I suspect my config could be wrong.
v.out.postgis --overwrite
input=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct at PERMANENT
output=PG:dbname=webgis
output_layer=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct
options=FID=cat, GEOMETRY_NAME=wkb_geometry, SPATIAL_INDEX=YES,
PRIMARY_KEY=YES
DBMI-PostgreSQL driver error:
select * from grass_gis.APGB_aerial_2_i_segment_drained_peat
_with_exposed_haggs_vct where 1 = 0
ERROR:  relation "grass_gis.apgb_aerial_2_i_segment_drained_
peat_with_exposed_haggs_vct" does not exist
LINE 1: select * from
grass_gis.APGB_aerial_2_i_segment_drained_peat...
*ERROR: Unable to describe table*
<grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct>
Thanks,
*Paul J. Shapley*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180628/a847145e/attachment.html>
