[GRASS-user] r.learn.ml does not write the feature importance file
Veronica Andreo veroandreo at gmail.com
Thu Nov 1 10:26:58 PDT 2018
Hi all,
I'm rather new in using machine learning classifiers (indeed I only started
to test today) and I found that setting fimp_file option does not give any
output. According to the manual, it should save the feature importances in
a csv file, but nothing comes out. Do I need to set permutations to a value
higher than the default 10 so as to get feature importance file or how does
it work?
I apologize if the question is very silly, I'm learning ;)
Thanks in advance!
Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181101/25db7667/attachment.html>
