[GRASS-user] partial vector copy to smaller territory
Frank David frank.david at geophom.fr
Fri Nov 2 10:31:55 PDT 2018
Le 02/11/2018 à 14:43, Markus Metz a écrit :
> On Fri, Nov 2, 2018 at 11:58 AM Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> wrote:
> > Le 31/10/2018 à 20:57, Markus Metz a écrit :
> > Hi Frank,
> > On Wed, Oct 31, 2018 at 1:39 PM Frank David <frank.david at geophom.fr
> > > Hello Vero,
> > > Thanks for your reply. It took almost one hour to extract my area
> (I guess because of topology). I do the same with Qgis from a shape in
> less than 10 minutes (but with several operations)... it's may be a
> bad idea to have a so heavy vector map in Grass...
> > this kind of operation could be much faster in latest GRASS 7.4 than
> in any previous versions. Which GRASS version are you using?
> > Hello Markus,
> > I'm using 7.4.1 on debian9
> > But my grass db folder  is on a small server (Synology NAS), so may
> be the network makes slow down the operation ?
> This is possible, but it should not slow it down that much: 10 min vs
> 1 hour
> Can you provide a link to the vector from which you want to extract a
> small area, and the command you used to extract a small area? Maybe
> there is scope for optimization.
Markus,
The data is CorineLandCover for france. You can download 400mo here >
https://we.tl/t-tvldlmkVw3
First I have imported the shape in PERMANENT
and I do : v.extract --verbose input=CLC12_FR_RGF at PERMANENT
where=CODE_12 IN (111,112,131,311,312,313,324) output=clc12
Hope it helps you...
Cheers,
Frank
> Markus M
> > Cheers,
> > Frank
> > Markus M
> > > Cheers,
> > > Frank
> > > Le 31/10/2018 à 11:26, Veronica Andreo a écrit :
> > > Check v.extract or v.clip
> > > Cheers,
> > > Vero
> > > El mié., 31 oct. 2018 7:20, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> > >> Hello,
> > >> What is the best and fast way to make a copy of a part of vector map
> > >> (national) to get a smaller territory ? (partial copy).
> > >> Thank you for your advice !
> > >> Frank
> > >> _______________________________________________
> > >> grass-user mailing list
> > >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > >> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181102/a3fafc09/attachment.html>
