[GRASS-user] r.tile behaviour
Veronica Andreo veroandreo at gmail.com
Wed Nov 7 10:06:24 PST 2018
Hi Sajid,
I have never used r.tile before, but checking the code [1], it multiplies
the overlap by 2, so there's why. Now guesstimating, if I set an overlap of
50, I would expect to have that overlap on both sides of the desired size
of the tiles, so maybe that's why it is doubled ?
HTH,
Vero
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.tile/main.c#L101
El mié., 7 nov. 2018 a las 15:08, Sajid Pareeth (<spareeth at gmail.com>)
escribió:
> Hi all
> The r.tile module don't have overwrite flag, so if we re run the module
> with different parameters but with same output prefix name, then it will
> rewrite output with out warning.
> Is this intentional?
> Another point is, if I use overlap option it adds double the overlap cells
> to the output maps.
> For example in the NC location:
>> r.info elevation -g
> rows=1350
> cols=1500
> r.tile input=elevation output=elev_tile width=750 height=675
>> r.info elev_tile-001-001 -g
> rows=675
> cols=750
> r.tile input=elevation output=elev_tile width=750 height=675 overlap=50
> rows=775 (+ 100)
> cols=850 (+ 100)
> In the last case the rows and cols should be 725 and 800 respectively, as
> it should add 50 cells as overlap to each tile? Or am I missing something?
> Regards
> Sajid
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181107/579805a0/attachment.html>
