[GRASS-user] r3.out.vtk for paraview
Francois Chartier fra.chartier at gmail.com
Wed Nov 21 04:44:46 PST 2018
I created 3 rgb maps using the same DEM file. should i be using 3 different
Dem or raster files instead?
Wouldnt it make more sense to be using RGB files developped based on the 3d
raster (even if that option doesnt exist).
On Nov 21, 2018 04:39, "Markus Neteler" <neteler at osgeo.org> wrote:
On Wed, Nov 21, 2018 at 4:06 AM Francois Chartier
<fra.chartier at gmail.com> wrote:
> Hi,
> I would like to export a 3D raster done with V.VOL.RST to view it in
paraview.
> With r3.out.vtk, i am using the DEM as the upper layer and another
bottom layer.  I created a RGB raster map based on the DEM, same raster for
3 colors.
> any ideas why this is not working?
> (Tue Nov 20 22:03:53 2018)
> r3.out.vtk -s --overwrite input=nov16region111 at Toronto output=VTKnov20
top=GTA_DEM_Raster at PERMANENT bottom=Rock at Toronto rgbmaps=geotechnov8 at Toronto
vectormaps=geotechNov8
> ERROR: Please provide three RGB 3D raster maps
> (Tue Nov 20 22:03:54 2018) Command finished (0 sec)
You need to specify three maps:
rgbmaps=name[,name,...]
    Three (R,G,B) 3D raster maps to create RGB values
[redmap,greenmap,bluemap]
Indeed, the [,name,...] is confusing here!
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181121/641f7d68/attachment-0001.html>
