[GRASS-user] buffer to wrap points
    Ken Mankoff
    mankoff at gmail.com
    Thu Nov 29 04:10:48 PST 2018
Hi Frank,
On 2018-11-29 at 12:46 +0100, Frank David <frank.david at geophom.fr> wrote:
> I did not find in v.buffer the way to create a common buffer on points
> if I want the buffer wraps all my points. Is there any tricks ?
Can you explain what you did and what happened and what you expected to happen? There is a section in the v.buffer man page "Circles around input points" that provides an example. Does this work for you?
  -k.
