[GRASS-user] zonal statistics for multiple areas
    Nikos Alexandris
    nik at nikosalexandris.net
    Tue Oct 30 03:50:45 PDT 2018
* Alessandro Sebastiani <alessandro.sebastiani at uniroma1.it> [2018-10-29 21:32:51 +0100]:
>thank you all for your suggestions.
>Dear Nikos, I have some 0-1 rasters that represents presence-absence of
>different land covers. Each raster's resolution is 10x10m, thus i want to
>compute the sum in order to obtain the surface covered by each land cover
>within my buffers. As regards to the buffer, i want to use the 0-100,
>0-200, 0-300, 0-400 and 0-500 for computing stats. I can do it separately
>with the module v.rast.stats. I just don't know how to loop it in a python
>script
Dear Alessandro,
I don't have time to write back as I would like. Instead, I will send
you off-list some unpublished script.  With a bit of reading, there, you
might identify some ideas that will eventually help in what you are
doing.
Kind regards, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181030/9cbf98b9/attachment.sig>
