[GRASS-user] Elevation above a river
Shane Carey careyshan at gmail.com
Sat Sep 22 06:47:16 PDT 2018
No worries, I'm not seeing any differences in the original and the filtered
cells. I've tried mode and max methods
Thanks
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
On Sat, Sep 22, 2018 at 2:39 PM, johannesradinger <
johannesradinger at gmail.com> wrote:
> Sorry I ment method=mode or median as stated by Markus N.
> Sent from my Samsung Galaxy smartphone.
> -------- Original message --------
> From: Shane Carey <careyshan at gmail.com>
> Date: 22/09/2018 15:05 (GMT+01:00)
> To: Johannes Radinger <johannesradinger at gmail.com>
> Cc: Markus Neteler <neteler at osgeo.org>, GRASS user list <
> grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] Elevation above a river
> This works a treat - super stuff - thanks Johannes.
> Could you point me in the direction of an algorithim with Grass that can
> do the following:
> # Clean some of the spurious cells etc. (using some kind of neighbourhood
> filtering)
> Thanks very much
> Le gach dea ghui,
> *Shane Carey*
> On Sun, Sep 16, 2018 at 8:46 PM, Johannes Radinger <
>> That is were the third step should follow, i.e. using r.mapcalc to
>> identify all the cells that are 1m higher than the grown river
>> (irrespective in which distance from the river these cells are located).
>> The rasterized area could then be translated into a vector format using
>> r.to.vect.
>> Here a small example of how the working flow could be using the North
>> Caroline example dataset:
>> # Set region
>> g.region raster=elevation at PERMANENT
>> # Extract elevation of the streams
>> r.mapcalc --o expression="streams_elevation = if(
>> streams_derived at PERMANENT, elevation at PERMANENT,null())"
>> # Grow stream_elevation map by a some hundred meters
>> r.grow -m --overwrite input=streams_elevation
>> output=streams_elevation_grow radius=500
>> # Calculate difference between original elevatoin and stream channel
>> elevation
>> r.mapcalc expression="stream_elevation_diff = elevation at PERMANENT -
>> streams_elevation_grow" --overwrite
>> # Extract areas that are than x meters higher than stream channel
>> elevation
>> r.mapcalc expression="stream_elevation_diff_smaller1 = if(
>> stream_elevation_diff < 1,1,null())" --overwrite
>> # Maybe here it needs some cleaning of spurious cells etc. (using some
>> kind of neighbourhood filtering)
>> # Raster areas to a vector area (with smoothed corners; s-flag)
>> r.to.vect -s --overwrite input=stream_elevation_diff_smaller1
>> output=stream_elevation_diff_smaller1_area type=area
>> HTH
>> /Johannes
>> On Sun, Sep 16, 2018 at 8:53 PM Shane Carey <careyshan at gmail.com> wrote:
>>> Hey Johannes,
>>> Thanks for your reply. How does r.grow work if let's say the height
>>> above the river reaches 1m at 3meters away from the river. And in an other
>>> area it reaches the 1meter height at 2meters away from the river. Is it
>>> able to follow that line?
>>> Thanks
>>> On Domh 16 MFómh 2018 at 17:21, Johannes Radinger <
>>>> To me this looks like a flooding-related question, i.e. to extract the
>>>> shore lines of a river if it's water level is raised by 1m or 3m?
>>>> Maybe (1) extract the raster cells of the elevation map that represents
>>>> the river channel, (2) then apply r.grow and (3) then r.mapcalc to subtract
>>>> the grown river channel from the original elevation map.
>>>> /Johannes
>>>> On Sun, Sep 16, 2018 at 5:16 PM Markus Neteler <neteler at osgeo.org>
>>>> wrote:
>>>>> Hi,
>>>>> Shane Carey <careyshan at gmail.com> schrieb am Fr., 14. Sep. 2018,
>>>>> 23:02:
>>>>>> Hi All,
>>>>>> Does anyone know is it possible to calculate the elevation above a
>>>>>> river channel (actual river network that was digitised as opposed to being
>>>>>> extracted from a DTM) from a DTM and create a polygon from it.
>>>>>> I need to calculate heights of 1m and 3m above a river channel on
>>>>>> both sides of the channel and create a polygon from it.
>>>>> This isn't clear to me. Could you elaborate?
>>>>> Best
>>>>> Markus
>>>>> Thanks all.
>>>>>> Le gach dea ghui,
>>>>>> *Shane Carey*
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>> Le gach dea ghui,
>>> *Shane Carey*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180922/5ae7066e/attachment-0001.html>
