[GRASS-user] Using g.tempfile
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue Sep 25 13:56:59 PDT 2018
Temp files are normally stored in the mapset (e.g. /grassdb/location/mapset/.tmp/YOURCOMPUTER/12345.0)
It can be partly controlled where tempfiles are stored using environment variables:
https://grass.osgeo.org/grass74/manuals/variables.html
https://grass.osgeo.org/grass74/manuals/g.gisenv.html
Cheers
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Rich Shepard
Sent: tirsdag 25. september 2018 22:49
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Using g.tempfile
   Running v.surf.tps stops after ~40% because it runs out of room to write a temp file. I assume that /tmp is the default directory for these files.
   The g.tempfile manual page wants a pid number. I can get this when I invoke the command, but not before. What's the recommended procedure for telling grass where to put temporary files prior to executing a running command?
TIA,
Rich
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
