[GRASS-user] wms google
Sebastián Dietrich sebadietrich at gmail.com
Mon Aug 5 10:54:17 PDT 2019
Thanks Micha for answering; i want to see satellite images from google (or
any other server) without downloading them; i.e., connect directly to the
server and see the images within the grass gis. I can't found the way to
connect to google server using WMS. I can use this in qgis, via xyz tiles (
http://localhost:8080/geoserver)
Thanks!
On Mon, Aug 5, 2019 at 1:54 PM Micha Silver <tsvibar en gmail.com> wrote:
> On 05/08/2019 19:45, Sebastián Dietrich wrote:
> Ken, thanks for your answer; but i meant to use xyz tiles in grass gis, in
> the manner qgis uses it...
> Can you clarify what you mean "in the manner qgis uses..."?
> You can import ASCII xyz files directly, and you can also import point
> clouds and interpolate a raster surface.
> On Mon, Aug 5, 2019 at 1:27 PM Ken Mankoff <mankoff en gmail.com> wrote:
>> On 2019-08-05 at 12:14 -04, Sebastián Dietrich <sebadietrich en gmail.com>
>> wrote...
>> > is it possible to load xyz tiles of google images as in qgis?
>> Yes. See "No plugin required" answer, not accepted answer, here:
>> https://gis.stackexchange.com/questions/20191/adding-basemaps-from-google-or-bing-in-qgis
>> > Did somebody get it work in grass?
>> I haven't tried yet.
>> I did just try exporting/saving a Google XYZ layer from QGIS to my
>> Desktop as a projected GeoTIFF and it did not seem to work.
>>   -k.
> grass-user mailing listgrass-user en lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190805/e3516572/attachment-0001.html>
