[GRASS-user] error in r.bioclim
Markus Metz markus.metz.giswork at gmail.com
Thu Aug 15 00:48:26 PDT 2019
On Wed, Aug 14, 2019 at 8:32 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hello,
> I'm preparing a workshop for geostat and I want to use r.bioclim. Data
was converted to degree C. This is the command i use:
> r.bioclim \
>   tmin=`g.list type=raster pattern="lst_minimum_??" separator=,` \
>   tmax=`g.list type=raster pattern="lst_maximum_??" separator=,` \
>   tavg=`g.list type=raster pattern="lst_average_??" separator=,` \
>   output=lst_ \
>   toutscale=1
> However, I get the following error, when the process reaches bio11 and
bio11:
> Mean temperature for each quarter year ...
> BIO10 = Mean Temperature of Warmest Quarter,
> BIO11 = Mean Temperature of Coldest Quarter ...
> ERROR: Raster map not found
> Traceback (most recent call last):
>   File "/home/veroandreo/.grass7/addons/scripts/r.bioclim", line 618, in
<module>
>     main()
>   File "/home/veroandreo/.grass7/addons/scripts/r.bioclim", line 316, in
main
>     method = 'maximum,minimum')
>   File
"/home/veroandreo/software/grass77-dev/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
line 441, in run_command
>     return handle_errors(returncode, returncode, args, kwargs)
>   File
line 343, in handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None r.series input=
output=lst_bio10.18931,lst_bio11.18931 method=maximum,minimum ended with
error
> Process ended with non-zero return code 1. See errors in the (error)
output.
> The input maps are there (12 Tmin, 12 Tmax and 12 Tavg), which is the map
it does not find then? Where do I find this (error) output??
this error was introduced by Markus N with
https://github.com/OSGeo/grass-addons/commit/7eb1fc10fcc7e56e93444a37287602ff41ec6a15#diff-53570b3d7e95af6c262896a8d57e367e
fixed in 7433d29b
Markus M
> Thanks in advance for any help
> Vero
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190815/9d4462a8/attachment.html>
