[GRASS-user] Creating location using EPSG code
    Ken Mankoff
    mankoff at gmail.com
    Mon Aug 26 20:22:22 PDT 2019
Hi Rich,
On 2019-08-26 at 23:10 +02, Rich Shepard <rshepard at appl-ecosys.com> wrote...
> The region in the project location is incorrect.
No. Setting the region and location are different things. You set the location with your "-c EPSG:2838".
> With only one small data set imported I decided to start over by
> deleting that location in /data/grassdata/.
You haven't shown the import command, but you can set the region from imported data with:
g.region (raster=... | vector=....)
Or explicitly:
g.region e=... w=... n=... s=... res=...
If setting with vector=... you'll need to set the "res" explicitly.
> What have I done incorrectly?
Not set your region, just your location.
  -k.
