[GRASS-user] error while using i.segment.stats
Veronica Andreo veroandreo at gmail.com
Thu Dec 5 04:04:57 PST 2019
Hi Moritz,
thanks for coming back to this topic :)
Here, the original region settings:
g.region -p
projection: 1 (UTM)
zone:       -21
datum:      wgs84
ellipsoid:  wgs84
north:      7168182
south:      7157384
west:       737450
east:       750236
nsres:      0.5
ewres:      0.5
rows:       21596
cols:       25572
cells:      552252912
Because of the error we reduced it by ~half, but still got the same error...
rows:       20478
cols:       13553
cells:      277538334
In the end, we solved it by extracting the stats per tile (cutlines
irregular tiles) and then patching...
best,
Vero
El jue., 5 dic. 2019 a las 9:35, Moritz Lennert (<
mlennert at club.worldonline.be>) escribió:
> On 3/12/19 13:26, Veronica Andreo wrote:
> > Hi Moritz,
> > Thanks for your answer :)
> > In smaller subsets (per cutlines tiles), it works just fine.
> With grass78 using python 3 ? Then probably it's not a python version
> issue.
> What is the region size ? When it is calculating the raster statistics
> it uses r.univar with extended statistics (-e flag), if the region size
> is too big, actually you are right that this might lead to memory errors
> if it tries to run 4 instances in parallel.
> Unfortunately, r.univar does not have a memory option allowing to limit
> memory usage. Maybe i.segment.stats should check the region size and
> available memory and bail out if there's not enough memory. Not sure how
> to calculate the needed memory size, though (especially since r.univar's
> -t flag is also set).
> You could also try to reduce parallelization, i.e. run it with two
> processes only. It will obviously be slower.
> Moritz
> > El mar., 3 dic. 2019 a las 12:41, Moritz Lennert
> > (<mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>)
> > escribió:
> >     Hi Vero,
> >     Le Mon, 2 Dec 2019 13:43:30 +0100,
> >     Veronica Andreo <veroandreo at gmail.com <mailto:veroandreo at gmail.com>>
> >     a écrit :
> >      > Hi,
> >      > We are trying to use i.segment.stats for a map with 800000+
> segments
> >      > and already in two different laptops, we get:
> >      > bands=`g.list rast pat=IGUAZU_IMG_* sep=,`
>  RASTER_STATS=(min,max,range,mean,stddev,median,first_quart,third_quart,perc_90)
> >      > AREA_STATS=(area,perimeter,compact_circle,compact_square,fd)
> >      > i.segment.stats -rc \
> >      >                  map=segments_full_region \
> >      >                  rasters=$bands \
> >      >                  raster_statistics=$RASTER_STATS \
> >      >                  area_measures=$AREA_STATS \
> >      >                  vectormap=segs_stats_map \
> >      >                  processes=4
> >      > Calculating geometry statistics...
> >      > Calculating statistics for raster maps...
> >      > Exception in thread Thread-3:
> >      > Traceback (most recent call last):
> >      >   File "/usr/lib/python3.6/threading.py", line 916, in
> >      > _bootstrap_inner self.run()
> >      >   File "/usr/lib/python3.6/threading.py", line 864, in run
> >      >     self._target(*self._args, **self._kwargs)
> >      >   File "/usr/lib/python3.6/multiprocessing/pool.py", line 463, in
> >      > _handle_results
> >      >     task = get()
> >      >   File "/usr/lib/python3.6/multiprocessing/connection.py", line
> 251,
> >      > in recv return _ForkingPickler.loads(buf.getbuffer())
> >      > TypeError: __init__() missing 3 required positional arguments:
> >      > 'module', 'code', and 'returncode'
> >      > Does it have to do with memory? I used the module a month ago with
> >      > 500000+ segments and it worked just fine...
> >     I don't think memory is the issue, but I find the error message
> >     pretty cryptic, so wouldn't exclude altogether. Could it be some
> >     difference between Python 2 and 3 in the multiprocessing module ?
> Would
> >     it be possible for you try running it in Python 2 ?
> >     Maybe you could also try to run it on a smaller subset of the
> >     segmentation result ?
> >     Moritz
> >     Département Géosciences, Environnement et Société Université Libre de
> >     Bruxelles Bureau: S.DB.6.138
> >     CP 130/03
> >     Av. F.D. Roosevelt 50
> >     1050 Bruxelles
> >     Belgique
> >     tél. + 32 2 650.68.12 / 68.11 (secr.)
> >     fax  + 32 2 650.68.30
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191205/6bf9e41a/attachment-0001.html>
