[GRASS-user] Adding map to layer manager (wxpython GUI) from grass console?
Veronica Andreo veroandreo at gmail.com
Thu Feb 7 05:42:41 PST 2019
Hi Joe,
well, I personally combine both depending on the task on hand. Most of the
time, I only use terminal though. When you start learning GRASS, there's a
nice feature of the GUI that allows to copy the command once you have set
all the options in GUI of that command. Like this you can copy the commands
into a text file and then comment and modify there, which allows for
reproducibility very easily
There's a lot of material online that you can follow, for example:
 - https://gitlab.com/veroandreo/curso-grass-gis-rioiv (links to
presentations and exercises in the README)
 - http://training.gismentors.eu/grass-gis-irsae-winter-course-2018/
cheers,
Vero
El jue., 7 feb. 2019 a las 13:59, Joe (<joe.on.list at gmail.com>) escribió:
> Thanks a lot Veronica!
> An other question: what way would you suggest to focus on for learning
> purpose?
> Monitors and terminal console, or a GUI based approach?
> Thank you again for you reply!  :)
> On Thu, Feb 7, 2019 at 11:50 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > Hi Joe
> > El jue., 7 feb. 2019 07:35, Joe <joe.on.list at gmail.com> escribió:
> >> On Wed, Feb 6, 2019 at 4:53 PM Rich Shepard <rshepard at appl-ecosys.com>
> wrote:
> >> > First, open a display monitor:
> >> > d.mon start=wx0
> >> > When you're finished, close the monitor:
> >> > d.mon stop=wx0
> >> > Of course, you can open multiple monitors (I don't know the maximum
> as I've
> >> > used only 2 at most) by incrementing the wxN integer.
> >> Thanks for yuor answer Rich, but in that way we would work on a new
> >> "stand alone" window (monitor), "basins" map is not added to the
> >> wxPython "Layer Manager". Look at this screenshot:
> >> https://cdn.pbrd.co/images/I028MO5.jpg
> >> We have wxpython GUI on the left with "Layer Manager" at top and "Map
> >> Display" at the bottom. On the right the new monitor window "wx0" and
> >> the terminal with grass prompt. As you can see the layer manager is
> >> empty.
> >> If I type the same command "d.rast basins at PERMANENT" at the layer
> >> manager console (top-left), the map is displayed in Map Display window
> >> and a new "layer" is added to the "Layers" tab of the layer manager:
> >> https://cdn.pbrd.co/images/I02qjCR.jpg
> >> https://cdn.pbrd.co/images/I02rk6A.jpg
> >> The question was: can I add the raster map "basins at PERMANENT" to the
> >> layer manager layers list by type a command at the terminal console
> >> (not using the wxpyton gui console)?
> > No, you can't. The terminal does not control the layer manager nor the
> main map display. From the terminal you need to open a wx monitor and then
> display maps there.
> > The main gui map display is controlled with the icons or the console tab
> in the layer manager.
> > HTH,
> > Vero
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190207/1433567d/attachment.html>
