[GRASS-user] postgresql geometry parameter not respected in v.in.ogr -r
patrick_s patrick_GIS at gmx.net
Tue Feb 26 08:05:06 PST 2019
Dear list
The syntax of v.in.ogr ignores the "geometry" Parameter, when using the
"spatial" Parameter or "-r". A workaround is the use of v.clip and g.rename.
I am a longterm user, but unregular user and have no userid to start a
ticket. Hope this helps for future development nontheless.
Best,
Patrick
#using flag "-r" and "spatial" finds "2990 vertices registered"
v.in.ogr spatial="2653156, 1249949, 2675000, 1267232"
input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o
v.in.ogr -r input="PG:dbname=psql_local" layer=${DBSCHEMA}.${DATASET}
out=gr_${DATASET}_${REFYEAR} type=point geometry="geom_2" -o --o #2990
vertices registered
#clipping with same region after loading reduces to "1079 primitives
registered"
v.clip in=gr_${DATASET}_${REFYEAR} out=gr_${DATASET}clip_${REFYEAR} -r
