[GRASS-user] How to generate a vector graphics file from GRASS CLI?
Ken Mankoff mankoff at gmail.com
Tue Jan 29 09:56:34 PST 2019
On 2019-01-29 at 18:42 +0100, Veronica Andreo <veroandreo at gmail.com> wrote...
> I just tested with the cartographic composer GUI (g.gui.psmap) and
> with command line ps.map, and as long as the other mapset is
> accessible, no problems with fully qualified map names, i.e.,
> map at mapset. No need to copy maps, you can use map at mapset in the
> instruction file
OK - maybe there was something else that was causing the problem for me. Thank you for testing and letting me know this does work.
  -k.
