[GRASS-user] Build error: git repo master
Rich Shepard rshepard at appl-ecosys.com
Thu Jul 18 08:57:54 PDT 2019
On Thu, 18 Jul 2019, Markus Metz wrote:
>> Aha! On my systems there's libgeos-3.7.2.so.
> yes, that's the error. Either "make distclean" or if that does not help
> figure out if there are two different GEOS installations, then remove one
> of them. Also check where libgeos.so is and where it points to.
Markus M,
After each build (or attempt) I run 'make distclean.'
There's only geos-3.7.2 installed.
On the 64-bit systems the libraries are in /usr/lib64/.
libgeos.so points to libgeos-3.7.2.so
so, I'll make a new softlink pointing libgeos-3.7.0.so to libgeos.so
Thanks,
Rich
