[GRASS-user] Python 3 Error using MultiModule and ParallelModuleQueue
Anika Bettge bettge at mundialis.de
Thu Mar 21 07:06:58 PDT 2019
Hello,
I try to write a GRASS addon, which does some preprocessing and
classifies with r.learn.ml on different region parallel. For this, I
want to use MultiModule and ParallelModuleQueue.
I tested the examples on
https://grass.osgeo.org/grass77/manuals/libpython/pygrass.modules.interface.html?highlight=parallelmodulequeue#pygrass.modules.interface.module.ParallelModuleQueue
with Python 3.
The example "Check MultiModule approach with three by two processes
running in a background process" leads to
      File "/usr/lib/python3.6/multiprocessing/queues.py", line 235, in
    _feed
        obj = _ForkingPickler.dumps(obj)
      File "/usr/lib/python3.6/multiprocessing/reduction.py", line 52,
    in dumps
        cls(buf, protocol).dump(obj)
    TypeError: can't pickle _thread.lock objects
The same error appears in the MultiModule example "Asynchronous module
run, setting finish = False and using temporary region".
Using python 2 all works fine.
Has someone a solution for the error or an idea how I can write a Grass
addon with parallelization on different regions?
Thanks and best regards,
Anika
P.S. I used this versions on Linux Mint 19 Tara:
python3 --version
Python 3.6.7
python --version
Python 2.7.15rc1
grass77 --config svn_revision version
74074M
7.7.svn
  Anika Bettge
  - Anwendungsentwicklerin -
  mundialis GmbH & Co. KG
  Kölnstraße 99
  53111 Bonn
  Tel: +49 (0)228 / 38 75 80 -80
  Fax: +49 (0)228 / 96 28 99 -57
  Email: bettge at mundialis.de
  Web: https://www.mundialis.de
  Amtsgericht Bonn, HRA 8528
  Komplementärin: mundialis Verwaltungsgesellschaft mbH
  vertreten durch: Dr. Markus Neteler, Hinrich Paulsen, Till Adams
  Informationen über Ihre gespeicherten Daten finden Sie auf unserer Homepage unter folgendem Link:
  https://www.mundialis.de/datenschutzerklaerung
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190321/b914f887/attachment.html>
