[GRASS-user] grass-7.9 does not find numpy
Markus Neteler neteler at osgeo.org
Sun Sep 1 13:20:39 PDT 2019
On Thu, Aug 22, 2019 at 5:57 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Mon, 19 Aug 2019, Markus Metz wrote:
> > Please post the full error message.
> Markus M,
> Starting GRASS GIS...
> ERROR: wxGUI requires wxPython. No module named wx
> You can still use GRASS GIS modules in the command line or in Python.
> ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
> On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
> To run GRASS GIS in text mode use the --text flag.
> Use '--help' for further options
>       grass79 --help
> See also: https://grass.osgeo.org/grass79/manuals/helptext.html
> Also, when I send the 'git pull' command instead of seeing a list of
> upgraded files I see this:
> remote: Compressing objects: 100% (12/12), done.
> remote: Total 24 (delta 14), reused 14 (delta 11), pack-reused 1
> Unpacking objects: 100% (24/24), done.
> From https://github.com/OSGeo/grass
>     f6edaaffa..494d10b10  master            -> origin/master
>     0afea5a41..329fab952  releasebranch_7_6 -> origin/releasebranch_7_6
>     d95f60bac..f582300b8  releasebranch_7_8 -> origin/releasebranch_7_8
> Updating 86354090c..494d10b10
> error: Your local changes to the following files would be overwritten by merge:
>         lib/python/ctypes/ctypesgencore/parser/lextab.py
run
git checkout lib/python/ctypes/ctypesgencore/parser/lextab.py
then update again. That glitch has been fixed recently but requires
this step (one time).
markusN
