[GRASS-user] Explain v.in.ogr error
Rich Shepard rshepard at appl-ecosys.com
Thu Sep 12 08:10:28 PDT 2019
On Thu, 12 Sep 2019, Moritz Lennert wrote:
> Could it be that your FileGDB contains raster data ?
Moritz,
Yes, it should be raster data.
> AFAIK, this not support by GDAL at the moment, and if it was, you would
> have to use r.in.gdal, not v.in.ogr.
That is the problem: FileGDB is not supported by GDAL and is not in the
r.in.gdal's list of suported formats.
Is there a tool to convert .gdb to something that r.in.gdal will accept? I'm
not going to have the source change the format as they use only ESRI's
ArcGIS and are likely limited to what export options that has.
Thanks,
Rich
