[GRASS-user] make fails to find Platform.make
Markus Metz markus.metz.giswork at gmail.com
Fri Sep 20 06:25:37 PDT 2019
On Fri, Sep 20, 2019 at 3:08 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Sep 20, 2019 at 2:21 PM Luí­s Moreira de Sousa <
luis.de.sousa at protonmail.ch> wrote:
> > Hi again Markus, thank you for following up.
> > In your example we can see this:
> > rm /home/mneteler/tmp//grass76/include/Make/Platform.make
> > make /home/mneteler/tmp//grass76/include/Make/Platform.make
> > How can it work? Is the file recreated somehow after the rm command?
What happens if you run only make include/Make/Platform.make?
> in this case "/home/mneteler/tmp//grass76" is the installation target,
"make install" cleans up leftovers from a previous installation. The real
Platform.make is in this example here:
/home/mneteler/software/grass76_git/dist.x86_64-pc-linux-gnu/include/Make/Platform.make
> to be installed to
> What is you install target, defined with configure --prefix= ?
Ah, I see. You configured with
/configure \
-prefix=/home/WUR/duque004/grass/
which will install GRASS to
/home/WUR/duque004/grass/grass-7.6.0
but that is also your source and build directory. You need to move the
grass source to somewhere else or use a different prefix
Markus M
>> Markus M
> > Regarding the volume: I think it is NFS, providing the user areas in
the HPC cluster.
> > Thanks you.
> > Luís
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190920/5dbf48ea/attachment.html>
