[GRASS-user] grass-7.8.5 on Fedora 33
mdwxman mdwxman at protonmail.com
Thu Dec 31 12:01:35 PST 2020
As a recent GRASS GIS-installation sufferer, I can explain what I did.  Basically I followed Markus Neteler's instructions explicitly for installing 7.8.5.  There were some small mistakes but he carefully corrected them.  I used his instructions from the User Group regarding 7.8.5, and the instructions called for a two-step process (or three steps): download the 7.8.5 source tarball, use the script preparing for the compilation (which guarantees all the required software is installed), then run the compile, make, make install steps.
Michael Allen
Industrial Weather
763-777-1263
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 23, 2020 7:33 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> I install from source, so cannot check. PROJ 7 needs Tiff and curl (to access
> the CDN) over and above the sqlite3 requirement introduced by PROJ 6. Is the
> install process pulling in PROJ > 6? I see 6.3.2 as the F33 current version,
> but >= 7 would explain complaints about missing Tiff:
> $ pkg-config proj --libs --static
> -L/usr/local/lib -lproj -lsqlite3 -ltiff -lcurl -lstdc++
> Roger Bivand
> NHH Norwegian School of Economics, Bergen, Norway
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
