[GRASS-user] r.hants and r.series.lwr in Windows
Helmut Kudrnovsky hellik at web.de
Fri Jun 26 02:05:08 PDT 2020
>there is somewhere an old ticket in trac.
see
https://trac.osgeo.org/grass/ticket/3432
https://trac.osgeo.org/grass/ticket/2919
 My guess - input.d8cut->answer contains extra chars (CR/LF issue?) and thus changing line to read:
if (strncmp(input.d8cut->answer, "infinity", 8) == 0) {
would solve the issue. Still, if it is so, then it is worth to digg deeper to see why it is failing as strcmp is used in many modules.
I guess that the MS Windows version of sscanf does not recognize infinity as a floating point number, while the Linux version does.
IMHO it's still worth to fix the issue with inf/INF as this issue pops up from time to time.
if it's not possible, the manual should be updated where needed that examples work also in winGRASS. PR welcome. :-)
kind regards
Helmut
