[GRASS-user] v.centerline addon
cesar at fototerra.com.br cesar at fototerra.com.br
Wed Mar 4 09:10:56 PST 2020
Hello!!!
I’m new user on GRASS and I’m trying to execute the addon v.centerline on
GRASS 7.9. As input I’m using a shapefile containing line (MultiLineString)
as geometry and when I have run the v.centerline an erro is returning:
“Traceback (most recent call last):
  File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts
/v.centerline.py", line 319, in <module>
    main()
/v.centerline.py", line 111, in main
    segment_input += 'P ' + category.strip()
TypeError: can only concatenate str (not "bytes") to str
(Wed Mar  4 17:27:25 2020) Comando terminado (3 segundos)
v.centerline input=Linha_rio_teste_Centerline at PERMANENT output=teste range=2
refline=2
    main()
(Wed Mar  4 17:27:28 2020) Comando terminado (2 segundos)”
I would like help to try understand what’s happening.
Regards.
César de Paula
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200304/ceba87e7/attachment.html>
