[GRASS-user] QGIS + GRASS GIS console
Valter Albino valteralbino at gmail.com
Mon Mar 23 07:51:56 PDT 2020
QGIS + GRASS GIS 7.8.2, in Windows 10, 64 OS, not working, when computed a
DTM from QGIS "TIN interpolation", followed bi "r.fill.dir":
QGIS version: 3.12.0-București
QGIS code revision: cd141490ec
Qt version: 5.11.2
GDAL version: 3.0.4
GEOS version: 3.8.1-CAPI-1.13.3
PROJ version: Rel. 6.3.1, February 10th, 2020
Processing algorithm…
Algorithm 'r.fill.dir' starting…
Input parameters:
{ '-f' : False, 'GRASS_RASTER_FORMAT_META' : '', 'GRASS_RASTER_FORMAT_OPT'
: '', 'GRASS_REGION_CELLSIZE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' :
None, 'areas' : 'TEMPORARY_OUTPUT', 'direction' : 'TEMPORARY_OUTPUT',
'format' : 0, 'input' :
'H:/FICHEIROS_DADOS/CARTOGRAFIA/MNT/MNT_1415/MNT_10K_2011/EPSG_3763/MDE_QGIS/mde2geral.tif',
'output' : 'TEMPORARY_OUTPUT' }
g.proj -c proj4="+proj=tmerc +lat_0=39.6682583333333
+lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0 +ellps=GRS80
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
r.in.gdal
input="H:\FICHEIROS_DADOS\CARTOGRAFIA\MNT\MNT_1415\MNT_10K_2011\EPSG_3763\MDE_QGIS\mde2geral.tif"
band=1 output="rast_5e78c95a53bf92" --overwrite -o
g.region n=-55000.37998979999 s=-80000.43 e=-31998.2197489 w=-63998.17
res=4.9992111
r.fill.dir input=rast_5e78c95a53bf92 format="grass"
output=output9c34ebfb2d204df1afd1d27147a3522b
direction=direction9c34ebfb2d204df1afd1d27147a3522b
areas=areas9c34ebfb2d204df1afd1d27147a3522b --overwrite
g.region raster=output9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input="output9c34ebfb2d204df1afd1d27147a3522b"
output="C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\0081688cca90464486f44241eca07462\output.tif"
format="GTiff" createopt="TFW=YES,COMPRESS=LZW" --overwrite
g.region raster=direction9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input="direction9c34ebfb2d204df1afd1d27147a3522b"
output="C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\54bb8b8a97534d53a90cfaa02ea9a703\direction.tif"
g.region raster=areas9c34ebfb2d204df1afd1d27147a3522b
r.out.gdal -t -m input="areas9c34ebfb2d204df1afd1d27147a3522b"
output="C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\734c1979cfb44de098ebea2a6ab5aad3\areas.tif"
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files...
Executing
<C:\Users\Particular\AppData\Local\Temp\processing_Dhabro\grassdata\grass_batch_job.cmd>
C:\Users\Particular\Documents>chcp 1252 1>NUL
C:\Users\Particular\Documents>g.proj -c proj4="+proj=tmerc
+lat_0=39.6682583333333 +lon_0=-8.13310833333333 +k=1 +x_0=0 +y_0=0
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
Default region was updated to the new projection, but if you have multiple
mapsets `g.region -d` should be run in each to update the region from the
default
Projection information updated
C:\Users\Particular\Documents>r.in.gdal
Over-riding projection check
Importing raster map <rast_5e78c95a53bf92>...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
C:\Users\Particular\Documents>g.region n=-55000.37998979999 s=-80000.43
e=-31998.2197489 w=-63998.17 res=4.9992111
C:\Users\Particular\Documents>r.fill.dir input=rast_5e78c95a53bf92
format="grass" output=output9c34ebfb2d204df1afd1d27147a3522b
ERROR: Raster map <output9c34ebfb2d204df1afd1d27147a3522b> not found
C:\Users\Particular\Documents>r.out.gdal -t -m
ERROR: Raster map or group <output9c34ebfb2d204df1afd1d27147a3522b> not
found
ERROR: Raster map <direction9c34ebfb2d204df1afd1d27147a3522b> not found
ERROR: Raster map or group <direction9c34ebfb2d204df1afd1d27147a3522b> not
found
ERROR: Raster map <areas9c34ebfb2d204df1afd1d27147a3522b> not found
ERROR: Raster map or group <areas9c34ebfb2d204df1afd1d27147a3522b> not found
C:\Users\Particular\Documents>exit
Execution of
finished.
Press any key to continue . . .
Execution completed in 62.54 seconds
Results:
{'areas': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT,
'createOptions': {'fileEncoding': 'System'}}>,
'direction': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT,
'output': <QgsProcessingOutputLayerDefinition {'sink':TEMPORARY_OUTPUT,
'createOptions': {'fileEncoding': 'System'}}>}
Loading resulting layers
The following layers were not correctly
generated.<ul><li>C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/0081688cca90464486f44241eca07462/output.tif</li><li>C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/54bb8b8a97534d53a90cfaa02ea9a703/direction.tif</li><li>C:/Users/Particular/AppData/Local/Temp/processing_Dhabro/734c1979cfb44de098ebea2a6ab5aad3/areas.tif</li></ul>You
can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm.
What should be?
Thanks in advance
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200323/a33522f1/attachment.html>
