[GRASS-user] Recommendations for v.surf.rst parameters for huge region
Anna Petrášová kratochanna at gmail.com
Tue Oct 20 19:12:53 PDT 2020
I don't have an answer but couple notes I can now think of:
- Variable density of points may be a problem, I sometimes had that issue
with gaps in lidar when it creates visible segments. In that case you need
to increase npmin, but that substantially increases processing time. The
default npmin is 300, but that is typically unnecessary, npmin 150 is
usually ok and runs faster. The segments can be mitigated as well by higher
tension. I usually use tension between 20-40. I haven't used smooth value
larger than 5 I think. But again, your data are probably quite different.
- v.surf.rst is parallelized, you need to compile GRASS with openMP to take
advantage of that
- Have you looked at r.fill.stats? I used it for lidar, first r.in.lidar
and then fill the rest with r.fill.stats, possibly multiple passes to fill
larger holes. It uses IDW, and it will be *significantly* faster, although
v.surf.rst would probably give you better results in the end.
Best,
Anna
On Fri, Oct 16, 2020 at 3:05 PM Eric Patton <eric.r.patton at protonmail.com>
wrote:
> Hello list,
> I am trying to interpolate raster values for a single massive dataset that
> represents dozens of multibeam bathymetry surveys over a few decades.
> The region is pretty big: all of Eastern Canada; at 100m resolution there
> are
> ~ 464M cells.
> The raster data has a wide range of completeness; in some areas, there is
> near 100% coverage - these areas were surveyed with modern sonars and 100%
> overlap between survey lines. In other areas, the data is very sparse, with
> ~1km or more between tracklines. These areas would represent surveys from
> the
> 70's to 90's using singlebeam echosounders.
> Firstly, would v.surf.rst be the best module for a massive interpolation
> job
> like this?  If not, could you recommend what would be the optimal method?
> If v.surf.rst is the right module to use, I was wondering if anyone could
> help
> with what parameters to use for an area this size, at least as a starting
> point. I have read the manual several times, but I still don't have a good
> intuition for how parameters like npmin, segmax, dmin, dmax, smooth all
> work
> together.
> At the moment, I have a script written that accepts a user-supplied number
> of
> random positions all over the input raster. For each random point, I obtain
> the east and north coordinates with v.to.db, feed these to g.region, and
> grow
> the region around the point in all four cardinal directions by some value
> like
> 10,000m to create an analysis window around each point. I create a polygon
> vector of this region with v.in.region, and use this polygon to clip my
> vectorized raster bathymetry with v.clip, and then do v.surf.rst on this
> clipped vector.
> I have no other way of knowing what v.surf.rst parameters to use other than
> trial and error, so I have a 4-level nested 'for' loop written to basically
> traverse through all permutations of the parameters within the ranges I
> chosen. So for example, I am exploring all combinations of parameters
> within
> these ranges:
> Tension: 10, 20, 40, 80, 160
> npmin: 100, 200, 400, 800, 1000
> smooth: 1, 2, 4, 8, 16, 32
> With 7 random points selected around the full region, this script will
> produce
> a few hundred maps per point, and quite a long time to run. And even more
> time
> to look at the results.  I know this isn't the best approach.
> I am looking for help to find some workable set of parameters to use for
> the
> entire dataset from other users who have more experience using this module.
> Thanks,
> Eric Patton
> Marine Geoscience Technologist
> Geological Survey of Canada (Atlantic)
> Natural Resources Canada
> Bedford Institute of Oceanography
> 1 Challenger Drive, Dartmouth NS, Canada
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201020/92bfa598/attachment.html>
