[GRASS-user] How to generate a random DEM Model of given size &	resolution
    BHARATH RAM
    br11 at iitbbs.ac.in
    Mon Sep 28 04:52:40 PDT 2020
Hello,
I want to generate a set of random DEMs ( epsg code known to me). I am
aware that I need to use r.surf.fractal and specify fractal dimension.
But how do I specify other parameters of the raster map (like length &
breadth, resolution?)
Also, can you guide me towards how generate a set of many such maps using
scripting?
Also, are there any tips for me to follow so as to make this (DEM raster
map) dataset generation as fast as possible?
I am a beginner to Grass (& a beginner to GIS software as well). So please
forgive me if the question is trivial.
Regards,
Bsr
*Disclaimer: *This email and any files transmitted with it are confidential
and intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify the
system manager. This message contains confidential information and is
intended only for the individual named. If you are not the named addressee
you should not disseminate, distribute or copy this e-mail. Please notify
the sender immediately by e-mail if you have received this e-mail by
mistake and delete this e-mail from your system. If you are not the
intended recipient you are notified that disclosing, copying, distributing
or taking any action in reliance on the contents of this information is
strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200928/8f30bc0a/attachment.html>
