[GRASS-user] v.select incredibly slow
Uwe Fischer gisfisch at t-online.de
Wed Apr 7 10:32:09 PDT 2021
Hello list, hello Markus,
it looks like I have the first issue with my update trials from GRASS 7.0.3 to 7.8.5. The following snippet worked fine in 7.0.3 (goal: to write out MicroStation CAD DGN-files from GRASS using a seedfile, which is just a template):
v.out.ogr input=gmarest at lwk_work type=line output=d:/testout.dgn format=DGN dsco=seed=d:/a-scratch/seed/lwk_seed.dgn
But in 7.8.5, I get:
ERROR 6: CreateField() not supported by this layer.
ERROR: Unable to create column <level>
I also set the –c flag to prevent GRASS from creating the CAT column since DGN only allows for certain columns, eg. LEVEL. But those cols were created without problems in the old version, so that cannot be the problem.
Thanks for help.
Mit freundlichen Grüßen,
Uwe Fischer
Ingenieurbüro Fischer
Esbecker Str. 8
31036 Eime
Tel.: 05182/8325
Mobil: 0172/8876934
Von: Markus Neteler [mailto:neteler at osgeo.org]
Gesendet: Montag, 29. März 2021 16:18
An: Uwe Fischer <gisfisch at t-online.de>
Betreff: Re: [GRASS-user] v.select incredibly slow
Hi Uwe,
Usually we are 99+ % backward compatible, at least aim to be it, as many of us use scripts written long time ago.
It could be that no changes are needed :)
Viele Grüße,
Markus
Uwe Fischer <gisfisch at t-online.de <mailto:gisfisch at t-online.de> > schrieb am Mo., 29. März 2021, 16:11:
Hi Markus,
thank you very much. I have planned that update for ages, but there are new versions in such quick succession that I am not sure when it would be best to make it real. I will let you know when I run into problems.
UWE FISCHER
Esbecker Str. 8
31036 Eime
Tel.: 05182/8325
Mobil: 0172/8876934
-----Ursprüngliche Nachricht-----
Von: Markus Neteler [mailto:neteler at osgeo.org <mailto:neteler at osgeo.org> ]
Gesendet: Montag, 29. März 2021 14:33
An: Uwe Fischer <gisfisch at t-online.de <mailto:gisfisch at t-online.de> >
Cc: GRASS user list <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> >
Hi Uwe,
On Mon, Mar 29, 2021 at 9:54 AM Uwe Fischer <gisfisch at t-online.de <mailto:gisfisch at t-online.de> > wrote:
> Hi Moritz & hi list,
> shame on me, I use 7.0.4. It has to do with some old clumsy scripts I
> produced and I never found the time to update (I'm not a GRASS professional or programmer, so things are quite hard for me). I am sure the v.select issue has to do with the old version. I will try soon with a newer one.
If you need support with the update, let us know. Likely only minor changes are needed.
It is definitely worth to reach GRASS GIS 7.8.x!
Best,
Markus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software https://grass.osgeo.org https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210407/54d640cb/attachment.html>
