[GRASS-user] Some new issues since installing some Python tools
Thomas Adams tea3rd at gmail.com
Mon Apr 19 05:01:07 PDT 2021
Hello Māris,
Yes here is what I found: my installation to anaconda3 was referenced twice
in my PATH...
This is what I have, now, that works:
echo $PATH
/home/teaiii/anaconda3/condabin:/home/teaiii/.cargo/bin:/home/teaiii/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Previously, I was also referencing anaconda3 following ":/usr/local/bin:"
-- once I removed the reference in my .profile and logged out and back in
again, my problem was resolved. Again, I am using GRASS (version 7.8.5 on
Ubuntu; Python 3.8.5, wxpython 4.1.1)
Thanks again and best wishes...
Tom
On Mon, Apr 19, 2021 at 1:48 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello Tom,
> please in a few words describe the issue and the solution you found.
> This will help others facing same error message to find solution by
> simple googling.
> Good to hear that you are back on a horse,
> Māris.
> 2021-04-16 13:57 GMT+03:00, Thomas Adams <tea3rd at gmail.com>:
> > Hi Māris!
> > I found the issue -- life is good again! Thank you so much!
> > Best regards,
> > Tom
> > On Fri, Apr 16, 2021 at 2:00 AM Maris Nartiss <maris.gis at gmail.com>
> wrote:
> >> Recompiling GRASS will not help. Look at your environment settings. In
> >> terminal examine output of env – most likely it contains some extra
> >> python paths that should not be there.
> >> Usual suspects of not playing nice are any python modules directly
> >> (ctypes, SWIG, ...) utilizing code from external compiled libraries
> >> (GDAL, wxWidgets, PROJ, ...). Make sure you are using only one python
> >> and its modules linking to other shared libraries are compiled with
> >> the same version of shared library. On Ubuntu package manager takes
> >> care of those aspects, in a virtual or mixed environment you are on
> >> your own.
> >> Good luck,
> >> Māris.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210419/965c5a03/attachment.html>
