[GRASS-user] v.rast.stats error: "Unable to seek"
Markus Neteler neteler at osgeo.org
Wed Feb 3 09:57:14 PST 2021
Hi Luí­s,
On Wed, Feb 3, 2021 at 5:51 PM Luí­s Moreira de Sousa via grass-user
<grass-user at lists.osgeo.org> wrote:
> Hi Stefan, thank you for the reply.
> The outputs you request are below. v.rast.stats takes about 8 GB of RAM before failing, only 1/4 of what is available in the workstation. I also tried increasing the memory parameter but it never goes above 8 GB and fails all the same.
If I am not mistaken, the memory= parameter isn't used at all in
v.rast.stats, hence not passed to v.to.rast:
https://github.com/OSGeo/grass/blob/e5afa5a8a0f8e39376f4ddfbda1a62abdef99a21/scripts/v.rast.stats/v.rast.stats.py#L167
For a test, you could use g.gisenv and set the "cache" memory to a
higher value (v.to.rast will respect it then):
https://grass.osgeo.org/grass78/manuals/variables.html#list-of-selected-internal-grass-environment-variables
--> MEMORYMB
Eg.
# set to 12 GB (default: 300 MB)
g.gisenv set="MEMORYMB=12000"
Not sure if that would help anyway.
However:
> Let me know if there is something else I can check. Thank you.
yes, you may try with "valgrind":
https://grasswiki.osgeo.org/wiki/GRASS_Debugging#Using_Valgrind
CMD="v.to.rast input=PSU output=test use=cat memory=10000"
valgrind --tool=memcheck --leak-check=yes --show-reachable=yes  $CMD --o
The output may give some hints (it will be long).
Best
Markus
