[GRASS-user] Error launching GUI in latest verison of trunk
Anna Petrášová kratochanna at gmail.com
Sun Feb 7 19:32:39 PST 2021
Before looking more into this, have you tried make distclean?
Anna
On Sun, Feb 7, 2021 at 5:20 PM Eric Patton via grass-user <
grass-user at lists.osgeo.org> wrote:
> Hi,
> I forget if these kind of errors should go to the dev list or the user's
> list, it's been so long since I've been on dev.
> Anyway, I get the following error launching the GUI after updating my git
> repo to Feb. 7th:
> Details: <free(): invalid pointer
> Traceback (most recent call last):
>   File "/home/epatton/.grass7/addons/scripts/r.mblend", line 281, in
> <module>
>     gscript.use_temp_region()
>   File "/usr/local/grass79/etc/python/grass/script/core.py", line 1285, in
> use_temp_region
>     run_command("g.region", flags="u", save=name, overwrite=True)
>   File "/usr/local/grass79/etc/python/grass/script/core.py", line 501, in
> run_command
>     return handle_errors(returncode, result=None, args=args, kwargs=kwargs)
>   File "/usr/local/grass79/etc/python/grass/script/core.py", line 393, in
> handle_errors
>     raise CalledModuleError(module=module, code=code,
> grass.exceptions.CalledModuleError: Module run g.region g.region --o -u
> save=tmp.r.mblend.265507 ended with error
> Process ended with non-zero return code -6. See errors in the (error)
> output.
> This is Grass 7.9 on Linux Mint 20.1.
> Eric Patton
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210207/ee126e3a/attachment.html>
