[GRASS-user] How would I make this odd choropleth in GRASS?
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 18 23:00:08 PST 2021
Am 19. Januar 2021 06:28:37 MEZ schrieb Dheeraj Chand <dheeraj at dheerajchand.com>:
>I have a shapefile of US counties in Texas. A map that I am trying to conceive would 1) separate the polygons to add some distance / whitespace between the constituting polygons 2) preserve their relative positioning 3) color the polygons on a graduation of average income and 4) while preserving shapes, increase or decrease size based on population .
>Am I crazy, is there such a map ? What would it be called or described as?
This generally called a cartogram or a chorogram: https://en.wikipedia.org/wiki/Cartogram?wprov=sfla1
Today the most used method, AFAIK, is this one:
https://www.pnas.org/content/101/20/7499
>How could I make this in GRASS?
You can't make this in GRASS GIS.
You can find code from one of the authors of above paper here: http://www-personal.umich.edu/~mejn/cart/.
QGIS used to have plugin for this: https://plugins.qgis.org/plugins/cartogram/
Don't know if that is still active.
Then there is scapetoad:
http://chorogram.choros.ch/scapetoad/chorogram.php
In R you can use Rcartogram: https://cran.r-project.org/web/packages/cartogram/index.html
Geoda and others also offer this functionality.
Moritz
