[GRASS-user] Median filtering time series in time only
Veronica Andreo veroandreo at gmail.com
Thu Jan 28 07:42:30 PST 2021
El jue, 28 ene 2021 a las 0:05, <nik at nikosalexandris.net> escribió:
> On 2021-01-27 16:59, Veronica Andreo wrote:
> Both r.series and t.rast.series will estimate the median per pixel in time
> (either for the whole series or the time period you want). Would it be
> possible then with so e sort of special for cycle?
> Sorry, I didn't pay attention. Reading more carefully.
> Indeed, r.series (t.rast.series) do the median. But they will just create
> a single pixel for each pixel time series.
> Then, as you write, it would take to hack-around a way to iterate over a
> given time series at the desired (number of) intervals, then compile a new
> time series.
> What is the 'e sort' part?
> Did you mean to type 'with some sort of...'?
> And what does the 'cycle' refer to?
Sorry Nikos! I was writing from my phone and it gets messy sometimes. The
intended sentence was: "Would it be possible then with some sort of special
`for loop`?"
> Thanks, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210128/7749d229/attachment.html>
