[GRASS-user] Creating a png file with multiple vector maps
Helmut Kudrnovsky
hellik at web.de
Tue Mar 2 11:38:40 PST 2021
>I don't see anything immediately wrong. Maybe it is a specific MS
>Windows issue I cannot reproduce here in GNU/Linux.
>@Helmut any ideas ?
tested here in the following way in OSGeo4W-winGRASS 7.8.5
(1) changing the working directory via GUI > change working directory
cd "D:\temp\testgrassrender"
Working directory changed to:
(2) in OSgeo4W-winGRASS-windows console (no msys needed!), also change here to the new wd:
C:\>cd D:\temp\testgrassrender
C:\>d:
(3) put the variables and d.-commands into a bat-file into the working directory (D:\temp\testgrassrender\mytest.bat):
REM start of the batch file
set GRASS_RENDER_IMMEDIATE=png
set GRASS_RENDER_WIDTH=640
set GRASS_RENDER_HEIGHT=480
set GRASS_RENDER_TRANSPARENT=true
set GRASS_RENDER_TRUECOLOR=true
set GRASS_RENDER_FILE_COMPRESSION=0
set GRASS_MESSAGE_FORMAT=plain
set GRASS_RENDER_FILE_READ=TRUE
g.region vect=census_wake2000
d.vect map=census_wake2000 fill_color=none
d.vect map=roadsmajor color=255:0:0:255
d.vect map=schools_wake fill_color=0:128:0:255 icon=basic/circle size=10
REM end of the batch file
=> see here: in order to set a variable in the windows world, use e.g. set GRASS_RENDER_IMMEDIATE=png instead if export GRASS_RENDER_IMMEDIATE=png in the *nix world
(4) start your batch file in the windows command line:
D:\temp\testgrassrender>mytest.bat
D:\temp\testgrassrender>set GRASS_RENDER_IMMEDIATE=png
D:\temp\testgrassrender>set GRASS_RENDER_WIDTH=640
D:\temp\testgrassrender>set GRASS_RENDER_HEIGHT=480
D:\temp\testgrassrender>set GRASS_RENDER_TRANSPARENT=true
D:\temp\testgrassrender>set GRASS_RENDER_TRUECOLOR=true
D:\temp\testgrassrender>set GRASS_RENDER_FILE_COMPRESSION=0
D:\temp\testgrassrender>set GRASS_MESSAGE_FORMAT=plain
D:\temp\testgrassrender>set GRASS_RENDER_FILE_READ=TRUE
D:\temp\testgrassrender>g.region vect=census_wake2000
D:\temp\testgrassrender>d.vect map=census_wake2000 fill_color=none
d.vect komplett.
D:\temp\testgrassrender>d.vect map=roadsmajor color=255:0:0:255
d.vect komplett.
D:\temp\testgrassrender>d.vect map=schools_wake fill_color=0:128:0:255 icon=basic/circle size=10
d.vect komplett.
(5) see attached the result png - it looks like the same as Moritz's example
kind regards
Helmut
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210302/b061dda8/attachment-0001.png>
