[GRASS-user] Building grass version grass-7.8.5
Stephen Kirby thinjogger at gmail.com
Fri Mar 26 15:13:18 PDT 2021
Thanks Veronica for that good information.  I've made some progress by
ensuring I had the libs it needs ready (GDAL, etc.).  Now it is giving me a
Python error :
 File
"/home/me/grass/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
line 305,
**options,
SyntaxError: invalid syntax
I am not a Python user so this is throwing me.  I assume I need to install
a Python (Python3?) module, via "pip install ..." I suppose.  Can someone
tell me which module can fix this?
For reference, the whole Python block of code containing the offending
line, from core.py is:
def make_command(
 prog,
 flags="",
 overwrite=False,
 quiet=False,
 verbose=False,
 superquiet=False,
 errors=None,
 **options,
Thanks for any ideas.
Best,
Steve
On Fri, Mar 26, 2021 at 12:25 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Steve,
> I'm no expert in compiling at all, but I always run configure in the
> source code directory. Have you tried?
> Once configure runs without errors, just run make, if no errors at the
> end, you are good to go
> Here's a wiki with instructions for diverse linux platforms:
> https://grasswiki.osgeo.org/wiki/Compile_and_Install
> hth,
> Vero
> El vie, 26 mar 2021 a las 18:07, Stephen Kirby (<thinjogger at gmail.com>)
> escribió:
>> Hi,
>> I am trying to build the version of GRASS listed in the subject line.
>> However, when I run configure, it does not produce a "Makefile" even though
>> configure appears to complete without error.  The closest thing I see to a
>> Makefile is this file:  include/Make/Platform.make.  I am not running
>> configure in the source code directory as one is always told this is a bad
>> idea (for ex., when building gcc).  I am running configure in a separate
>> directory ("/build-grass").  Let me know what I should try next as I am
>> excited to get GRASS running!
>> Best regards,
>> Steve
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210326/fe58f2d9/attachment.html>
