[GRASS-user] Unable to export vector data after upgrading to GRASS 8
Amit Ghosh
ghoshamitag at gmail.com
Mon Apr 4 03:38:13 PDT 2022
I tried to export a vector file to use it in another application. The
module returns an error message that says "Unable to create OGR spatial
reference". The detailed output is here:
> v.out.ogr input=MDG_UNSALB_admin3_selectionSN5 at PERMANENT
> output=/home/amit/Documents/mdg_aoi2_.gpkg
> ERROR 10: Pointer 'hSRS' is NULL in 'OSRImportFromWkt'.
> ERROR: Unable to create OGR spatial reference
Projection info
> g.proj -p
> -PROJ_INFO-------------------------------------------------
> datum : wgs84
> ellps : wgs84
> proj : aea
> lat_0 : 0
> lon_0 : 25
> lat_1 : 20
> lat_2 : -23
> x_0 : 0
> y_0 : 0
> no_defs : defined
> towgs84 : 0.000,0.000,0.000
> -PROJ_UNITS------------------------------------------------
> unit : meter
> units : meters
> meters : 1
I cannot figure out where I am wrong. Can you suggest an alternative?
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220404/14e6f139/attachment.html>
