[GRASS-user] Unable to export vector data after upgrading to GRASS 8
Amit Ghosh ghoshamitag at gmail.com
Mon Apr 4 05:08:57 PDT 2022
It shows:
> v.info MDG_UNSALB_admin3_selectionSN5 at PERMANENT
>  | Mapset:          PERMANENT
>  | Location:        southern_africa_grass
>  | Database:        /run/media/amit/InternalHD/FAO/country
>  | Title:
>  | Map scale:       1:1
>  | Name of creator: amit
>  | Organization:
>  | Source date:     Tue Mar 22 17:47:24 2022
>  | Timestamp (first layer): none
>  | Map format:      native
>  |   Type of map: vector (level: 2)
>  |   Number of points:       0               Number of centroids:  7
>  |   Number of lines:        0               Number of boundaries: 27
>  |   Number of areas:        7               Number of islands:    2
>  |   Map is 3D:              No
>  |   Number of dblinks:      1
>  |   Projection: Africa_Albers_Equal_Area_Conic
>  |               N:  -2374864.5344628    S: -2811333.16032851
>  |               E:  2422280.61532197    W:  2266547.34604055
>  |   Digitization threshold: 0
>  |   Comment:
On Mon, 4 Apr 2022 at 17:20, Micha Silver <tsvibar at gmail.com> wrote:
> On 04/04/2022 14:29, Amit Ghosh wrote:
> Dear Mr. Micha,
> Yes, it is EPSG: 102022,  I used the proj4 string to create the location.
> Many thanks for the solution. It worked. However, the v.out.ogr module
> exports the file without the CRS.
> What does v.info MDG_UNSALB_admin3_selectionSN5  show ??
> Projection information updated
>> (Mon Apr  4 16:44:33 2022) Command finished (0 sec)
>> (Mon Apr  4 16:44:45 2022)
>> g.proj -p
>> -PROJ_INFO-------------------------------------------------
>> datum      : wgs84
>> ellps      : wgs84
>> proj       : aea
>> lat_0      : 0
>> lon_0      : 25
>> lat_1      : 20
>> lat_2      : -23
>> x_0        : 0
>> y_0        : 0
>> no_defs    : defined
>> -PROJ_SRID-------------------------------------------------
>> SRID       : EPSG:102022
>> -PROJ_UNITS------------------------------------------------
>> unit       : meter
>> units      : meters
>> meters     : 1
> v.out.ogr input=MDG_UNSALB_admin3_selectionSN5 at PERMANENT
>> output=/home/amit/Documents/mdg_unsalb_east_mdg.gpkg format=GPKG
>> proj_create: crs not found
>> Exporting 7 areas (may take some time)...
>> v.out.ogr complete. 7 features (Polygon type) written to
>> <MDG_UNSALB_admin3_selectionSN5> (GPKG format).
>> (Mon Apr  4 16:45:39 2022) Command finished (0 sec)
>> Kind regards,
> Amit
> On Mon, 4 Apr 2022 at 16:33, Micha Silver <tsvibar at gmail.com> wrote:
>> Hello:
>> On 04/04/2022 13:38, Amit Ghosh wrote:
>> > Hi,
>> > I tried to export a vector file to use it in another application. The
>> > module returns an error message that says "Unable to create OGR
>> > spatial reference". The detailed output is here:
>> >     output=/home/amit/Documents/mdg_aoi2_.gpkg
>> >     ERROR 10: Pointer 'hSRS' is NULL in 'OSRImportFromWkt'.
>> >     ERROR: Unable to create OGR spatial reference
>> > Projection info
>> >     g.proj -p
>> I would guess that this is the problem:
>> >     datum      : wgs84
>> >     ellps      : wgs84
>> >     proj       : aea
>> >     lat_0      : 0
>> >     lon_0      : 25
>> >     lat_1      : 20
>> >     lat_2      : -23
>> >     x_0        : 0
>> >     y_0        : 0
>> >     no_defs    : defined
>> >     towgs84    : 0.000,0.000,0.000
>> >     unit       : meter
>> >     units      : meters
>> >     meters     : 1
>> > I cannot figure out where I am wrong. Can you suggest an alternative?
>> How did you initially create the GRASS Location? Is the albers equal
>> area projection described by a standard EPSG code? It appears to be this
>> one:
>> https://epsg.io/102022
>> **IF** that's the correct projection, then you should be able to do:
>> echo
>> "PROJCS["Africa_Albers_Equal_Area_Conic",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["longitude_of_center",25],PARAMETER["Standard_Parallel_1",20],PARAMETER["Standard_Parallel_2",-23],PARAMETER["latitude_of_center",0],UNIT["Meter",1],AUTHORITY["EPSG","102022"]]"
>> | g.proj -c wkt=-
>> That long WKT string will reset the projection definition of the
>> Location, then you should be able to export OK.
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> Micha Silver
>> Ben Gurion Univ.
>> Sde Boker, Remote Sensing Lab
>> cell: +972-523-665918
> Micha Silver
> Ben Gurion Univ.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220404/17c813df/attachment.html>
