[GRASS-user] largest number of consecutive days where rainfall >1 mm
Veronica Andreo
veroandreo at gmail.com
Thu Aug 18 06:36:23 PDT 2022
Hi Ivan,
It does indeed count consecutive days meeting a condition per week. That's
what the [-1] means in the t.rast.algebra command, i.e., it is the temporal
neighbourhood modifier. If you then want to get the largest weekly
consecutive days meeting the condition within a month you can aggregate the
"weekly_consecutive" time series with t.rast.aggregate granularity="1
month" method="maximum"
HTH,
Vero
El jue, 18 ago 2022 a las 14:42, Ivan Marchesini (<ivan.marchesini at gmail.com>)
escribió:
> Hi Markus
> thank you
> Yes I saw that algorithm but, if I'm not wrong, it does not fit with my
> needs. The calculation made returns the number of days, in a given
> interval (here week), that meets a certain condition. Not sure they are
> consecutive. As an example: if negative temperature occur in monday and
> thuesday and then in friday, saturday and sunday then the code count 5
> for that week. In my opinion what we need is 3.
> I hope I was enough clear
> In any case it would be good to find a solution for this type of problem
> because these type of indexes are used for climate data analysis (e.g.:
> https://www.ecad.eu/download/millennium/millennium.php
> https://www.climdex.org/learn/indices/ )
> thank you
> Ivan
> On 17/08/22 20:04, Markus Neteler wrote:
> > Hi Ivan,
> > On Wed, Aug 17, 2022 at 9:07 AM Ivan Marchesini
> > <ivan.marchesini at gmail.com> wrote:
> >> Dear grass user
> >> I have daily rainfall strds
> >> I would like to obtain a layer of the largest number of consecutive days
> > May this script code help?
> https://grasswiki.osgeo.org/wiki/Temporal_data_processing#How_to_count_consecutive_days_that_meet_a_certain_condition
> > Markus
> >> Do you have any suggestions on how to calculate this climate index using
> >> grass's time modules?
> >> thank you very much
> >> Ivan
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220818/4c6af518/attachment.htm>
