[GRASS-user] Export raster to PostGIS
Asim
asimrp at lavabit.com
Fri Aug 26 00:47:58 PDT 2022
Hello
Is it possible to export a raster map created using r.water.outlet to
PostGIS in GRASS 78? The documentation indicates using r.out.gdal with
PostGISRaster as format. The command I'm trying is the following:
r.out.gdal input=mywatershed format=PostGISRaster output=mywatershed
createopt="PG:dbname='mydb'"
The postgresql server is running with locally and the database "mydb"
can be accessed without having to enter a password using psql client.
However, this command fails with the error:
ERROR 6: PostGISRasterDataset::CreateCopy() only works on source
datasets that are PostGISRaster
Is something wrong in the command? The error message seems to suggest
that it is impossible to export the raster map created with
r.water.outlet to PostGIS because it is not sourced from PostGIS. Can
someone please confirm?
Asim
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220826/5382a4f8/attachment.htm>
