[GRASS-user] Probabilistic neighborhood analysis
Veronica Andreo veroandreo at gmail.com
Mon Dec 26 07:12:50 PST 2022
Hello Bernardo,
I haven't tested myself, but have you tried r.neighbors with the different
weight-related options?
Vero
El mié, 14 dic 2022 a las 10:38, Bernardo Santos via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hi,
> I am trying to produce scenarios of past land cover, before hydropower
> reservoirs were built. To do so, I need to fill empty pixels from a raster
> in the locations where the reservoirs are currently present, using as input
> the actual land cover map. I tried doing that with r.neighbors (taking
> method=mode) with neighborhoods of increasing size, to replace null pixels
> with the most common land cover class in the neighborhood. I also tried
> that with r.fill.stats which is basically the same thing.
> However, the results gets very homogeneous, since the interpolated null
> cells always get the value of the most common land cover class.
> Do anyway know of a method in GRASS to perform a "probabilistic"
> neirighborhood analysis, where cells in a neighborhood are given weights
> (possibly related to the distance to the central cell and to their
> frequency) and these weights are used to stocastically sample a value to
> fill the central cell?
> If not in GRASS, does anyway know of such a method in a different
> platform, i.e. R?
> Thanks!
> Best
> Bernardo
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221226/614226e5/attachment.htm>
