[GRASS-user] Rscript error when using v.class.mlR
Daniel Kozar djkozar at ucdavis.edu
Sat Feb 19 16:55:21 PST 2022
Hi Micha,
Thanks for the reply. I ran the script lines you sent both in the terminal
as well as a GRASS session. Rscript is recognized in the terminal command
but not in the GRASS 8.0 command. Since GRASS 8.0 did not recognize Rscript
I tried making a symbolic link for "Rscript" to the full path:
/usr/local/bin/Rscript. This still doesn't recognize the command and I'm
unsure how else to work around it.
Any Mac aficionados reading this - do you have an idea to resolve this?
Thanks
Daniel
On Sat, Feb 19, 2022 at 1:46 AM Micha Silver <tsvibar at gmail.com> wrote:
> Hi
> On 19/02/2022 04:27, Daniel Kozar via grass-user wrote:
> > Hi everyone,
> > When using the extension "v.class.mlR" I get an error [Message 1] (see
> > below) that "Rscript" cannot be located. I traced this back to the
> > script for "v.class.mlR" and edited line 908 to read the direct path
> > to Rscript - '/usr/local/bin/Rscript' rather than 'Rscript' alone.
> > However, when I re-open GRASS 8.0 I get an error [Message 2] that the
> > extension failed when loading and that the operation isn't permitted.
> > I allowed for the application to have administrative rights but it
> > still doesn't work. Does anyone know how to work around this or solve
> > the issue finding "Rscript"?
> > I have R running and have installed necessary packages. I'm
> > running GRASS on MacOS Monterey.
> This looks like a Mac problem (which I know nothing about).
> To test, can you run, first from a terminal:
> micha at RMS:~$ Rscript -e "sessionInfo()"
> Now run the same from within a GRASS session:
> (here's what I get)
> micha at RMS:QGIS$ g.version
> GRASS 8.1.dev (2022)
> micha at RMS:QGIS$ Rscript -e "sessionInfo()"
> R version 4.1.2 (2021-11-01)
> Platform: x86_64-pc-linux-gnu (64-bit)
> Running under: Debian GNU/Linux 11 (bullseye)
> Matrix products: default
> BLAS:   /usr/lib/x86_64-linux-gnu/openblas-pthread/libblas.so.3
> LAPACK: /usr/lib/x86_64-linux-gnu/openblas-pthread/libopenblasp-r0.3.13.so
> locale:
>   [1] LC_CTYPE=en_GB.UTF-8       LC_NUMERIC=C
>   [3] LC_TIME=en_GB.UTF-8        LC_COLLATE=en_GB.UTF-8
>   [5] LC_MONETARY=en_GB.UTF-8    LC_MESSAGES=en_GB.UTF-8
>   [7] LC_PAPER=en_GB.UTF-8       LC_NAME=C
>   [9] LC_ADDRESS=C               LC_TELEPHONE=C
> [11] LC_MEASUREMENT=en_GB.UTF-8 LC_IDENTIFICATION=C
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods base
> loaded via a namespace (and not attached):
> [1] compiler_4.1.2
> If the Rscript executable is not found, then v.class.mlR cannot be run.
> > Any help would be appreciated.
> > - Daniel
> > *[Message 1]*
> > Running R now. Following output is R output.
> > Traceback (most recent call last):
> > File "/Users/dankozar/Library/GRASS/8.0/Addons/scripts/v.class.mlR",
> > line 977, in <module>
> > main()
> > line 908, in main
> > subprocess.check_call(
> > File
> > "/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py",
> > line 368, in check_call
> > retcode = call(*popenargs, **kwargs)
> > File
> > line 349, in call
> > with Popen(*popenargs, **kwargs) as p:
> > File
> > line 951, in __init__
> > self._execute_child(args, executable, preexec_fn, close_fds,
> > File
> > line 1821, in _execute_child
> > raise child_exception_type(errno_num, err_msg, err_filename)
> > FileNotFoundError: [Errno 2] No such file or directory: 'Rscript'
> > *[Message 2]*
> > Details: <[Errno 1] Operation not permitted: 'v.class.mlR'>
> > WARNING: Some addons failed when loading. Please consider to update
> > your addons by running 'g.extension.all -f'.
> > Thank you,
> > Daniel Kozar
> > PhD Candidate
> > UC Davis - Hydrologic Sciences
> > (814) 380-6900
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
Thank you,
Daniel Kozar
Graduate Student
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
(814) 380-6900
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220219/cff43b5b/attachment.html>
