[GRASS-user] 8 Release Candidate
Randal Hale rjhale at northrivergeographic.com
Sun Jan 23 06:40:55 PST 2022
I've been trying to run the 8 release candidate. I'm on a stock Ubuntu
(21.10) install and I've downloaded the binary 8 release candidate for
grass. I do have Grass 7.8.5 running.
Anyway - I've installed in a custom location and in the default. I start
grass and get. The GRASS Splash screen does come up and stays up for
about 2 secs and then I'm sitting at the prompt. I can't get the GUI up
and running. Thoughts (I can file a bug report if needed):
./grass
Starting GRASS GIS...
Cleaning up temporary files...
           __________  ___   __________    _______________
          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
        \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS GIS 8.0.0dev (4d15e3313)
GRASS GIS homepage:https://grass.osgeo.org
This version running through:            Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
See citation options with:               g.version -x
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS world_latlong_wgs84/PERMANENT:bin > Traceback (most recent call last):
   File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
     lambda event: event.callable(*event.args, **event.kw) )
   File "/home/rjhale/temp/grass/gui/wxpython/wxgui.py", line 86, in show_main_gui
     from lmgr.frame import GMFrame
   File "/home/rjhale/temp/grass/gui/wxpython/lmgr/frame.py", line 45, in <module>
     from gui_core.preferences import MapsetAccess, PreferencesDialog
   File "/home/rjhale/temp/grass/gui/wxpython/gui_core/preferences.py", line 52, in <module>
     from gui_core.dialogs import SymbolDialog, DefaultFontDialog
   File "/home/rjhale/temp/grass/gui/wxpython/gui_core/dialogs.py", line 44, in <module>
     from gui_core.gselect import (
   File "/home/rjhale/temp/grass/gui/wxpython/gui_core/gselect.py", line 62, in <module>
     from grass.lib.imagery import (
   File "/home/rjhale/temp/grass/etc/python/grass/lib/imagery.py", line 30, in <module>
     _libs["grass_imagery.8.0"] = load_library("grass_imagery.8.0")
   File "/home/rjhale/temp/grass/etc/python/grass/lib/ctypes_loader.py", line 89, in __call__
     raise ImportError("Could not load %s." % libname)
ImportError: Could not load grass_imagery.8.0.
Randal Hale
https://www.northrivergeographic.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220123/9a2943f0/attachment.html>
